What is Unit Management?
When working with Quantity items you will have many different units of measure in use. Units such as pieces, kilograms, buckets, boxes, liters, meters, pallets, and more are critical to your day to day. ON!Track allows you to flexibly manage these units. We have created a list of predefined units for you to use. See the table below. You can also create any unit that you need.
  • Predefined Units: These units are predefined and localized to fit regional or industry-specific requirements. They cannot be edited.
  • Custom Units: Users with appropriate permissions can add, edit, and delete custom units to tailor unit management according to organizational needs. [Add Link Here]
Listed below are the predefined units available in ON!Track:
Unit Name Unit Description
box Box
can Can
ft Feet
kg Kilogram
lb Pound
liter Liter
pc Piece
sheet Sheet
ton Ton
yd Yard
Note:
  • Predefined Units cannot be deleted.
  • Units currently assigned to any Quantity Item cannot be deleted.
To learn how to add custom unit, please check: How to Add Custom Units (Unit Management)?
