How can I disconnect (or turn off) a gateway?
Stationary Gateway (AI G125)
You can turn off a Stationary Gateway (AI G125) by disconnecting the power cable. After unplugging the main power connection, wait about 30 seconds before reconnecting.
Van Gateway (TU-600)
You can turn off a Van Gateway (TU-600) by removing it from the OBD port of the vehicle.
Telematics Gateway (TU-600)
You can turn off a Telematics Gateway (TU-600) by removing it from the OBD port of the vehicle. Please be aware that this might be challenging due to its complex installation.
If disconnected, the gateway will show as offline in ON!Track and will not function properly.
Note: It may take up to 10 minutes after rebooting for assets detected by the gateway to be visible in ON!Track.
1 out of 1 found this helpful
