You can use the following methods to verify if the warehouse or stationary gateway is displaying incorrect/no location, or if it is not transmitting any data: My Stationary Gateway is showing an incorrect location/no location/is not sending any data
- Check if the gateway is plugged into the power source.
- Check the LED status on the vehicle or telematics gateway. Click here to learn more about the available color options and our expert recommendations for each.
Inspect for any physical or cable damage.
To ensure minimum physical or cable damage follow the following preventive measures:
- Ensure cables are installed without overstretching, pinching, or sharp bends.
- Use cable clips, ties, and trays to keep cables organized and reduce stress.
- Route cables and gateways away from high foot traffic, water, and direct sunlight.
- Regularly check cables for wear, exposed wires, discoloration, or texture changes.
- Check if the location has good connectivity.
How do I check the modes , what do I do about each mode how do make it active if its not?
ON!Track does not have a UI to display the vehicle’s mode. If the vehicle is moving faster than 8 km/h, it is in Active Mode. For more details, check the provided resources, gateway's mode (Active, Inactive, Sleep, Deep Sleep): What are the different modes of Vehicle or Telematics Gateway (TU-600)?
If you checked everything and still not working you can connect with us. For other Hilti tools, reach Customer Service at Hilti Contact Page, call 0800 888 55 22.
