Yes - You can transfer the Telematics Gateway (TU-600) between different machines within the same account (e.g., from a dumper to a forklift). However, this process requires significant effort, similar to the initial installation.
The gateway must be physically moved, and you will need to offboard it and then re-onboard to the new machine within the ON!Track application.
If you want to perform such a move, we suggest you get in touch with your local sales contact. Keep in mind that you might need a professional installer for this, which could involve additional implementation costs.
