Roles: Administrator & Employee | Interface: Mobile
You will learn to edit the service details for heavy equipment using mobile application.
Instruction:
- Open the dashboard, click "Assets" and select the required asset.
- To edit the service, go to the asset details, and scroll down to the "Upcoming Services" section. You can view the assigned services for the required asset here.
- Open the service details, click on the three dots, and select "Edit." Update the schedule for the next service as needed, then click "Save Changes."
- The service will be updated in the asset details.
If you are interested in learning how to edit the assigned services for heavy equipment using the web platform, please check: How do I edit assigned service for my heavy equipment using web platform?
If you are interested in learning how to assign services for heavy equipment using the web platform, please check: How to assign services for heavy equipment using web platform?
If you are interested in learning how to assign services for heavy equipment using the mobile application, please check: How to assign services for heavy equipment using Mobile Application?
