How do I reschedule services from alerts for my heavy equipment using mobile application?
Roles: Administrator & Employee | Interface: Mobile
You can reschedule a service from either the “Complete Service” options or by using the “Reschedule Service” option on the alerts section in the application.
Instructions:
  • Open the dashboard, click "Alerts". The alert list will open. Search for and select the alert you need.
  • Select the alert, click the three dots, and choose "Reschedule Service" to finish the service.
    • You can also complete the service from this dropdown.
  • Update the field (Next service scheduled at) and click “Save Changes.” You’ll find the updated service in the alerts tab. Click on it to view the details.
  • You can also view the rescheduled service in the assets. Open the dashboard, click "Assets" and select the required asset.
  • Scroll down in the asset details and click "Upcoming Services" to view the updated or rescheduled services.
If you are interested in learning how to view service alerts and alert details for the heavy equipment  using the web platform, please check: How do I view service alerts and alert details for my heavy equipment using web platform?
If you are interested in learning how to view service alerts for heavy equipment using the mobile application, please check: How do I view service alerts details for my heavy equipment using mobile application?
If you are interested in learning how to edit assigned services for heavy equipment using the web platform, please check: How do I edit assigned service for my heavy equipment using web platform?
If you are interested in learning how to edit assigned services for heavy equipment using the mobile application, please check: How do I edit assigned service for my heavy equipment using mobile application?
If you are interested in learning how to reschedule services for heavy equipment using the web platform, please check: How do I reschedule services from alerts for my heavy equipment using web platform?
