Roles: Administrator | Interface: Web
When a service is completed, it is saved as a "Historic Service." If the service is recurrent, multiple historic records may exist. You can edit these historic records, including the "Completed At" value.
Instructions:
- Click on the asset tab and search for the required heavy equipment asset.
- Scroll down the asset details section and click on the historic services.
- Use the dropdown to view "Historic Services". Locate the current instance of a recurring service that has been completed. Click "Edit".
Update any info e.g. the completion kilometers to edit the historic service instance and click “Complete” to finish.
- Note - If you edit "Completion kilometers" or "Completion hours" on the most recent completed instance of a recurring service, the schedule for the next instance of that service will be updated to match the change. Refer to the article here -> [Link - https://ontrack3.zendesk.com/knowledge/editor/01J69K79KWVQK0308N8G80BV3H/en-us?brand_id=25140334256539]
- You can find the modified service under "Historic Services."
If you are interested in learning how to edit the latest completed historic service for heavy equipment on the mobile application, please check: How to edit the latest completed historic service for heavy equipment on the mobile application?
If you are interested in learning how to edit the latest completed historic service for heavy equipment on the web platform, please check: How to edit the latest completed historic service for heavy equipment on the web platform?
