How to edit the latest completed historic service for heavy equipment on the web platform?
Roles: Administrator | Interface: Web
The upcoming service will stay on its original schedule only if you edit a completed one-time service or the last completed instance of a recurring service. But if you edit the most recent completed instance of a recurring service, it will affect the schedule for the next service.
Instructions:
  • Click on the asset tab and search for the required heavy equipment asset.
  • Scroll down the asset details section and click on the historic services.
  • Use the dropdown to view either "Historic Services" or "Upcoming Services."
  • Switch to "Historic Services" from the dropdown, then select and open the service you need and click on edit to start the editing process.
  • Update the completion kilometers and click “Complete” to finish.
  • You can find the modified service under "Historic Services."
  • Update the completion kilometer value for the most recent instance.
  • If the user selects that the "For upcoming services" should get updated, then that schedule change is reflects appropriately in the system.
  • If the user selects updates only "for the service" then the upcoming service instance stays as per original schedule.
  • Here click on the "For upcoming services" and then click "Done".
  • You will see the service is updated in both historic services and upcoming services.
If you are interested in learning how to edit historic service instance for heavy equipment using web platform of a recurring service, please check: How to edit historic service instance for heavy equipment using web platform of a recurring service?
If you are interested in learning how to edit the latest completed historic service for heavy equipment on the mobile application, please check: How to edit the latest completed historic service for heavy equipment on the mobile application?
