A feature that allows users to view all active tagged or IoT-enabled tools (e.g., Gateways, Bluetooth tags or Nuron) on a single map.
When you open the Smart Map, you will only see tools that are active, tagged, or IoT-enabled (e.g., Nuron). Tools will show their latest location only if there is an update from a Gateway scan, the ON!Track app, or a Nuron charger.
For tools tracked by stationary gateways, their location on the map will match the address of the warehouse or job site where the gateway is installed.
Benefits:
- Track Equipment: See where your equipment is across different locations.
- Optimize Movement: Manage asset movement to avoid delays.
- Reduce Downtime: Find and use equipment faster to minimize downtime.
- Improve Efficiency: View all assets on a map for smoother operations.
- Simplify Management: Easily keep track of valuable equipment.
The below steps can help users navigate to Smart Map.
Instructions:
- Click on the "Smart map" tab.
Assets and Clusters:
On the Smart Map, tools are displayed as either individual assets or clusters.
- Individual Assets: Tools shown separately on the map.
- Clusters: Groups of tools located close together, displayed as a single cluster.
Instructions:
- The map automatically adjusts to show assets individually or as clusters based on the zoom level.
- You can zoom in further to expand the cluster and view the list of individual assets.
- Assets with the same location coordinates will always appear as clusters, even when zoomed in fully. Clicking on a cluster will display a list of all assets within it.
If you want learn more about the smart inventory feature of smart map, please check: How does the Smart Inventory feature work on the Smart Map?
