You can generate the heavy equipment utilization report by selecting the report template of your choice.
Instructions:
- To generate a report from a user-created template, go to Reports → Templates, select the required template, and click Generate report.
- Add the details to generate the report (Report file name, Date range filters) and then click on Generate.
The generated report will be visible under the "Generated Report" tab.
- Please note: The report will be automatically deleted 90 days after it is generated.
- Currently, reports show as "In Progress." Click "Refresh" to update the status to "Generated."
- To download the report, select it and click "Download."
- You can view the generated report in Excel format.
If you want to know more about heavy equipment utilization report and services report templates, please check: What are heavy equipment utilization report and services report templates?
If you want to know more about editing report template (user template) for heavy equipment utilization report, please check: How to edit report template (user template) for heavy equipment utilization report?
