How to Delete Custom Units (Unit Management)?
This section will equip you with the knowledge to efficiently delete units of measure in ON!Track, ensuring precise tracking and reporting of material and tool usage.
Instructions:
  • Click on the "Unit Management" from the tab Administration --> General.
  • Select the required manufacturer and click on "Delete" to delete a custom manufacturer.
  • The selected unit will be deleted from the unit list.
Please note that if there is a unit linked to the quantity Item, they must be unlinked/changed before deleting the unit from the unit list.
To learn how to edit custom unit, please check: How to Edit Custom Units (Unit Management)?
