How to Edit/Rename Label?
Before you begin using labels, it's essential to know what they are and where they're used:
Labels form the foundation for future reporting and display capabilities, enabling us to provide you with project-related data to increase management efficiencies.
  • Locations, Unique Assets / Quantity Items, and Employees can be linked together as per user preference using Labels.
  • One or more Labels can be assigned to one or more Locations, Unique Assets / Quantity Items, or Workers.
  • Any Location, Unique Asset / Quantity Item or Worker can have up to 50 Labels
Let's go through how you can rename/edit a label, and where you can apply it to Locations, Unique Assets/Quantity Items, and Employees.
Instructions:
  • Click on the "Labels" from the tab Administration --> General.
  • When you click this, you'll be taken to the label's window. You can select the label you want to rename/edit from the existing list.
  • Rename the label as per requirement (refer to the example below):
  • Once you select "yes," the change will be reflected in the label's name.
    To learn how to add a label, please check: How to Add Label?
