How to delete a Manufacturers?
Warehouse or facility managers often need to streamline the process of adding assets and quantity items into the ON!Track system. One way to achieve this is by setting up predefined manufacturers.
This allows managers to quickly select manufacturers when adding new items, ensuring accurate and efficient inventory management.
Instructions:
  • Click on the "Manufacturers" from the tab Administration --> Assets.
  • Select the required manufacturer and click on "Delete" to delete a manufacturer.
  • The selected manufacturer will be deleted from the manufacturer list.
Please note that if there is a manufacturer linked to an Asset, Template or Quantity item, they must be unlinked/changed before deleting the manufacturer from the manufacturer list.
To learn how to merge two manufacturers, please check: How to merge two Manufacturers?
