ON!Track allows you to create and use asset templates, simplifying the management of your asset fleet. A template can be associated with multiple assets with similar attributes, including manufacturer, model, image, and description. Utilizing templates helps you maintain consistency and efficiency throughout your assets.
Instructions:
- Click the assets, then select "+" to add the asset.
You can start filling out the details to create an asset.
- Enter the asset details.
- Enter the additional information.
- Add services if the asset requires them (Optional selection).
- Select the service from the dropdown, enter the status, and the next service date, and click "Assign."
- Here you can view the service and its details.
- Scroll down to drag and drop a file, or click to browse and upload any file and optional notes. Check the asset costs and click on "Complete".
- The asset is successfully created.
- You can view the asset in the Asset List.
If you want to add an asset template under the Administration Tab, you can check: How to add an asset template under the administration tab?
If you want to add an asset template when creating an asset, you can check: How to add an asset template when creating an asset?
