How to edit asset template?
ON!Track allows you to create and use asset templates, simplifying the management of your asset fleet. A Template can be associated with multiple Assets with similar attributes, including manufacturer, model, image, and description. Utilizing templates helps you maintain consistency and efficiency throughout your assets.
Instructions:
  • Click on the Administration --> Templates.
  • Search and select the required template and click on "Edit".
  • Edit the template details, and asset costs, or add/remove services and attachments as needed. (For this article we edit the asset cost). Click on Save Changes.
  • Your Changes will be saved in the template.
If you want to create an asset with a template, you can check: How to create an asset with a template?
If you want to delete the asset template, you can check: How to delete the asset template?
