How to delete the asset template?
ON!Track allows you to create and use asset templates, simplifying the management of your asset fleet. A Template can be associated with multiple assets with similar attributes, including manufacturer, model, image, and description. Utilizing templates helps you maintain consistency and efficiency throughout your assets.
Instructions:
  • Click on the Administration --> Templates.
  • Search and select the required template and click on "Delete".
  • A warning will appear asking if you're sure you want to delete the template. Click "Delete" to confirm and remove it.
  • The template will be deleted from the template list.
Note:
You can delete templates that do not have any assets linked to them. To delete these, simply remove the linked assets from the template.
If you want to merge the asset templates, you can check: How to merge asset templates?
If you want to edit the asset template, you can check: How to edit asset template?
