How can you download delivery note through the transfer function on the mobile application?
Roles: Administrator & Employee | Interface: Mobile
In the transfer workflow, a delivery note is automatically generated when an asset is moved from one location to another. This document provides details of the transfer and serves as a record for tracking purposes. To ensure awareness, users responsible for the asset will receive an email notification about the initiated transfer.
This process helps maintain transparency and accountability in asset management.
Instructions:
  • Select the asset you want to transfer and click on "Transfer".
  • Click on the "View transfer cart" and select the required attributes, select either "Location," "Storage Asset," or "Employee," choose the required value and then click on "Transfer now".
  • Add the task code and notes (if needed), and signature (if needed), review and edit the remaining data as necessary, then click "Confirm".
  • The asset will be transferred to the designated location, and the sender and receiver will receive a delivery note via email, which can also be downloaded from the email.
If you want to know about the delivery note, and how you can view and download it through the Transfer function on the web Platform, you can check: How can I view and download the delivery note through the transfer function on the web platform?
If you want to know about the delivery note and how you can view and download it through the quick transfer function on the web Platform, you can check: How can I view and download the delivery note through the quick transfer function on the web platform?
