The export Asset List feature in ON!Track enables users to generate an Excel report containing key tracking details of all assets within their tenant. It offers insight into when and by which source each asset was last detected, assisting users in tracking asset movements and ensuring data accuracy.
Who Can Access This Feature?
Any user with access to the Smart Map tab in ON!Track can export the asset list. This access is granted through:
- A custom role assigned by an administrator
- The Admin or Support Admin role
How Does It Work?
- Navigate to the Smart Map tab in ON!Track.
- Locate the Export icon in the top right corner.
- Click the Export icon to generate an Excel file.
Instructions:
- Select the Smart Map tab on the screen.
- To export the asset list from the Smart Map, click on the "Export" icon. The system will generate and download an Excel file containing the asset details.
- Here, you can view all asset attributes in the Asset List, including Name, Scan Code, Inventory Number, Serial Number, and more.
Enhancement to asset export from Smart Map
We have added new columns “Last Used Date” and “Last Used Time” to show when a tool was last used. This helps you find tools and assets which are not being used and move them where they’re needed.
Example: If a drill was last seen on August 15th, but last used on July 10 at 3:15 PM, it has been probably left unused for almost a month. You can then move it to another location where it’s more needed.
Go to the Smart Map tab, select the required filter, and click Export. Open the Asset Detail sheet, go to Customize Sort, and sort by "Last Used Date".
Search for the asset and check its "Last Used Date."
What is included in the exported file?
The Excel file will contain the following tracking information for each asset:
- Last Seen Date
- Last Seen Time
- Last Seen Within (a source that last detected the asset)
- Last Used Date
- Last Used Time
Notes:
- This feature is available only on the web version of ON!Track.
- Users without access to the Smart Map tab cannot use this functionality.
- The system might slow down if the number of assets exceeds 30,000.
When you apply one or more filters on this page, such as by Last Seen Date, Last Seen Time, or Last Seen Within, those same filters will also be applied to the data when you export it. This ensures that the exported list matches exactly what you see on the screen.
- For example, if you select 'Last 3 Days' as the filter, the data will only include assets that were last seen within that specific time frame.
Users can efficiently track and manage assets by utilizing the Export Asset List feature, improving asset visibility and operational efficiency.
If you want to know more about how I sort the exported asset list by "Last Seen Date" and "Last Seen Time", click here: Can I sort the exported asset list by "Last Seen Date" and "Last Seen Time"
If you want to know more about Smart Maps, click here: What is the Smart Map
