An API (Application Programming Interface) is like a bridge that helps different software applications talk to each other. It lets your asset management software automatically share data with other tools you use, saving you time and reducing mistakes.
If you want to know how to connect ON!Track Unite with other software, please check: How to Link ON!Track with External Systems and What to Do If Yours Isn’t Supported
If you want to know what Unite is, please check: What is ON!Track Unite
If you want to know if you can access all ON!Track data through the API Please check: Can I access all ON!Track data through the API?
