Discover ON!Track
What is ON!Track?
We know how burdensome equipment and material management for our construction users can be and how much time effort is required. What we observed when we asked our construction users what their biggest pain points are around equipment and material management:
The time and money wasted on these processes could be much better invested on your jobsites and for better experience. Right?
Right! That’s why we offer you a holistic solution to manage your equipment and material. ON!Track helps you getting more transparency on all your equipment and material, independent from the manufacturer, so that you become more productive.
How can ON!Track help you becoming more productive?
Tracking of your equipment and material
Where is my equipment?
Track all brands, not just Hilti. View equipment and material from small drill drivers to 40-ton excavators and see exactly where they are, including in your vans. On top, keep your inventory at your fingertips.
When you know where to find equipment and assets, you don’t lose valuable time looking for items or waste money buying or renting replacements. Some of the key functionalities that ON!Track supports:
  • Know where your tools are
  • Know how your tools are being used
  • Know who is using your tools
  • Help identify and reduce downtime due to missing tools
  • Help reduce hoarding
  • Lower the risk of theft
  • Know which tools are idle and available to use
How can I manage my consumables?
Running out of consumables on the jobsite can lead to costly emergency orders. ON!Track helps you identify when your inventory may be running low and will alert you when it's time to reorder.
  • View and manage supplies and receive low-stock alerts.
  • Run reports to identify wasteful spending.
Connected Tool Services: How can I become smarter on my Hilti tools?
Designed for construction, Hilti’s combined Tool Services deliver high-performing cloud-connected tools at a fixed monthly rate and powerful asset tracking with usage and location data for maximum transparency. By combining Tool Fleet Management with ON!Track and the Nuron cordless platform you can manage your workforce and jobsites with more efficiency.
The Nuron cordless platform, enabled by Fleet and ON!Track, allows you to quickly check battery state of health and proactively order replacements. Access services that help you find missing equipment or identify under-used or hoarded tools. And use the data from Nuron to help make informed decisions about your tool crib without interruptions to your workflow.
Safety and Maintenance: are my tools safe to use?
Know who has what equipment, how long they've had it and whether they're certified to use it. Check tool safety and compliance requirements. Some key functionalities:
  • Be audit-ready for all your equipment with "one-click" management of your daily reports and safety documents
  • Schedule and track maintenance and repairs of all your assets in your inventory
  • Access equipment documentation and service records directly from the jobsite
  • Gain insights into what needs to be replaced.
Profitability: What are the costs incurred by equipment and material?
Manage any asset, any brand, and costs from multiple jobsites – all on one digital platform. We provide you with a hassle-free cost allocation based on equipment usage, calculated by the number of days on-site.
  • Flexible Rates: Choose daily, weekly, or monthly cost schedules.
  • Quick Calculations: Determine costs per jobsite in seconds.
  • ERP Integration: Export data seamlessly to ERP systems via ON!Track Unite.
  • Cost Capping: Set limits to ensure no further charges once the accumulated cost reaches a predefined threshold.
Integration: How can I connect ON!Track with my other Software Solutions?
Catapult your productivity to new heights by sharing ON!Track data with the software you already use. From ERPs to accounting software, a growing list of pre-built ON!Track integrations can be found in the Unite Marketplace. If you require an integration that is not on the list, you have two options: either have your IT department build your own connector using our open-APIs or hire a 3rd party to build the connector for you. All information needed to build a connector can be found in the Developer Hub.
Explore more: https://unite.ontrack3.hilti.com/
What does ON!Track contain? A powerful combination of Software, Hardware and Services
Software:
Module / Bundle  Ready  Lite  Pro  Enterprise
  Manage your Hilti Fleet tools  Manage & digitize all your tool park  Automate all your tool park  Manage your company
Hilti fleet tool management
Equipment management
Asset Cost Reporting   -
Manage your Quantity items   -
ON!Track Unite (API integrations)
Proactive Asset Tracking with
Gateways (Warehouse, Van, Heavy, Equipment)
Login to ON!Track on your desktop: Link Or download the app
HARDWARE: Our Hardware is behind ON!Track
ON!Track is a state-of-the-art Internet-of-Things (IoT) Solution and hence provides a comprehensive combination of tags (sending data), gateways (receiving data) and accessories so that you can manage your entire tool park across different locations (e.g., warehouse, jobsite, transit area)
Tags Gateways Accessories
Passive tags (optimal for your
low-value material/equipment):
Small tags (AI L2)
Large tags (AI L5)
Warehouse Gateway (AI G125) – optimal for tracking inventory in your warehouse
For your tags:
Holder with cable ties Holder with metal rope 3M tape Metal holder
Active tags (optimal for higher
value material/equipment that
you want to track proactively in
combination with a Gateway)
Smart tag (AI T320)
Runtime tag (T320R)
Geo Tag (AI T400)
Vehicle Gateway (TU-600) – optimal for tracking the location and inventory of your vehicles For your gateways: OBD cable OBD flat cable Heavy cable Holder
  Heavy Gateway (TU-600) – optimal for tracking the location, inventory / near-by assets of your heavy machines and for optimizing the utilization.
More details on our hardware portfolio can be found here: ON!Track Supported Hardware Overview
Services: How do I get started?
We as Hilti do not leave you alone on the transformation journey. We provide a comprehensive offering of support so that you can fully benefit from our ON!Track solution. Our service offering contains:
  • Onsite discovery consultation.
  • Full implementation with data upload and material/equipment tagging.
  • Onsite training and change management support.
  • Post-implementation care and support.
Speak to us about ON!Track
Learn how ON!Track can help transform your business, making it more efficient, compliant and cost-effective.
7 out of 8 found this helpful
