An employee can only be deleted when they no longer have any active responsibilities in ON!Track.
Active Assignments Blocking Deletion
The following assignments may prevent an employee from being deleted:
- Responsible employee for an asset
- Owner of an asset
- Default employee for an asset
- Responsible employee for a quantity item
- Location manager for an active location
When you want to delete an employee
- Navigate to the "Employee" Tab: Select the particular employee whom you need to delete. Click on the "Delete" icon at the top to delete the employee.
If the employee has any active responsibilities, a dialogue window opens listing all blocking items grouped by category:
Assets: The employee is assigned as the responsible employee, owner, or default employee.
Quantity items: The employee is assigned as the responsible employee.
Locations: The employee is assigned as the location manager.
- Use the links provided (Click the chevron (›) next to an item in the list) to open the affected records and reassign them to another employee.
- Return to the deletion window and confirm that all blocking assignments have been resolved.
Confirm the deletion
Once all active assignments are cleared, click Delete.
Review the final confirmation message.
Click Confirm to complete the deletion.
- The employee will be deleted, and will be removed from the employee list.
Points to remember:
Retired or disposed assets
Retired and disposed assets are considered inactive.
- They are not included in the employee deletion process.
- They do not prevent an employee from being deleted.
- Links from the deletion dialog do not open retired or disposed assets.
If an employee is deleted while still referenced by retired or disposed assets, and the employee name is anonymised as "XXXX XXXX".
Assignment counts may be different
You may notice that the number of assignments shown in the employee details page differs from the number shown during employee deletion.
This is expected.
The employee details page includes all assignments associated with the employee, including retired and disposed assets.
The deletion process only shows active assignments that must be resolved before deletion. It also considers assignment types that may not appear in the same way on the employee details page, such as asset owners and default employees.
Because these views serve different purposes, the numbers may not match.
Archived locations
Archived locations are treated as inactive.
If an employee is deleted while assigned to an archived location, the employee name is anonymised as "XXXX XXXX" in the archived record.
If the location is later reactivated, a new location manager must be assigned.
Default employee for automated onboarding
If the employee is configured as the default employee for Hilti Assets automated onboarding, this assignment is not displayed in the employee deletion process.
You must remove this configuration before the employee can be deleted.
If you still can't delete the employee
Before trying again, make sure that:
- All asset assignments have been removed or reassigned.
- All quantity item assignments have been removed or reassigned.
- All active location manager assignments have been updated.
- The employee is not set as the default employee for Hilti Assets automated onboarding.
- You have the Delete Employee permission.
If the employee still cannot be deleted, contact ON!Track Support and provide:
- The employee's name.
- A screenshot of the error message.
- The assignment categories and counts shown in the deletion message.
- Confirmation that all visible assignments were reviewed.
