How to delete an Asset or Kit (Storage Asset)
How to Delete an Asset
  • Permissions Needed:
    Only users with "Admin" or "Delete Assets" permissions can delete assets. Check your permissions if you don’t see the delete option.
  • Check Asset Status:
    • Assets that are "In-Transit" (transferred but not yet confirmed delivered) cannot be deleted.
    • Assets that have been transferred at least once can only be deleted if the company setting for asset deletion is enabled.
  • Follow Below Steps to Delete an Asset:
    • Click on Assets tab to open the asset list view.
    • Select one or multiple assets to delete at once.
    • Now click on Delete icon to delete the selected assets.
  • Bulk Deletion:
    • You can delete more than one asset at a time from the asset list view.
  • After Deletion:
    • All history, transfers, tracking, service records, and attachments for the asset are permanently deleted.
    • Any alerts for the deleted asset are cleared.
    • The asset’s scan code, inventory number, or serial number can be reused for new assets.
  • Alternative:
    • If you want to keep the asset’s history, consider marking it as "Disposed" or "Retired" instead of deleting it.
How to Delete a Kit (Storage Asset)
  • Important:
    • Before deleting a kit (storage asset), make sure all subordinate (child) items are transferred to another location. They will no longer be listed as part of the kit after deletion.
  • Follow the Same Steps as for Assets:
    • Select one or multiple Kits (storage assets) to delete at once.
    • Now click on Delete icon to delete the selected asset(s).
Important:
  • Storage Assets:
    • Cannot be deleted if they still have associated items (child assets or quantity items).
    • If child assets are in "Disposed," "Retired," or "Lost" status, temporarily set them to "Operational" to edit or remove them.
    • Make sure the storage asset is not present in any inventory or export reports before deletion.
  • GPS Tags:
    • If an asset or kit has a GPS tag, deleting it will automatically de-link the tag, making it available for reassignment.
Note: If you cannot delete an asset or kit due to system restrictions, contact your system administrator or support team for help.
