Before deleting an asset in ON!Track, users must meet the following prerequisites.
Prerequisites for deleting an Asset
- Not in transit: The asset should not be in a transfer process or marked as "in transit."
- Correct permissions: Only users with the right permissions (such as Admin or Delete Assets) can delete assets.
- Company setting enabled: The company setting for asset deletion must be enabled if required.
- Transferred assets: If the asset was transferred, deletion is only possible if the company allows deleting transferred assets.
- No child assets: For storage assets, ensure there are no child assets or quantity items linked.
General Tips
- Use export features: Export any important data before deletion, as deleted records may not be recoverable.
- Ask your admin: If you are unsure, contact your system administrator for help with permissions or dependencies.
In short:
You can only delete an asset, if you have the right permissions. Always check for active assignments or dependencies before trying to delete.
