Asset and Quantity Item Costs
What are Asset and Quantity Item Costs?
  • Asset Costs: Charges assigned to equipment (like drills, rotary hammers, cranes, excavators, etc.) based on how long they are used at a jobsite.
  • Quantity Item Costs: Costs for materials or consumables (like drill bits, scaffolding, etc.) used or consumed at a jobsite.
Why are they important?
  • Helps track and allocate costs to specific projects or jobsites.
  • Encourages efficient use of equipment and materials.
  • Supports internal cost transparency and external invoicing (e.g., charging branch offices or sub-suppliers).
How does it work?
Asset Costs
  • Calculated for each period an asset spends at a cost location (jobsite or warehouse).
    Below is the formula to calculate the asset costs:
    Asset cost = (Workdays on Site) x (Daily asset cost) x (Quantity of Assets)
    Note: In the case of Unique Assets, Quantity is always 1.
  • Key details tracked:
    • Date arrived and left
    • Days and workdays on site
    • Current asset cost
  • Asset cost is shown only if the asset stays at a location for at least 30 minutes.
  • Asset costs are visible for the last 6 months by default.
  • Reports can be generated for up to 1 year in the past.
Related articles on Asset Cost:
For the detailed information on asset cost, please refer to the below articles:
Quantity Item Costs
  • Quantity cost is calculated per allocations.
    Below is the formula to calculate the quantity items costs:
    Quantity item cost = (Workdays on Site) x (Daily asset cost) x (Quantity at that allocation)
  • Daily costs can be added when creating or cloning a quantity item.
  • Separate tab available for viewing quantity item costs.
  • If no costs are recorded, a message will indicate the list is empty.
Related article on Quantity Item Cost:
For the detailed information on quantity item cost, please refer to the below article:
User Access & Permissions
  • Access to cost modules can be enabled or disabled by admins.
  • Permissions control who can view or edit cost settings and reports.
  • Settings can be managed at company, location, template, or individual asset/item level.
Benefits
  • Saves time by automating cost calculations (no more manual notes).
  • Increases accuracy and reliability of cost data.
  • Makes it easy to charge projects for equipment and material use.
  • Flexible reporting for better project management and profitability analysis.
