On!Track provides powerful and flexible search on the asset list, allowing you to quickly find assets using either multi-keyword search or exact match search.
Multi-Keyword Search
- You can type multiple words separated by spaces, like: Hilti Charger John.
- On!Track looks for each word across different asset fields (e.g., manufacturer, model, responsible worker).
- The system shows assets that contain all the words, even if they appear in different places.
- Example:
- “Hilti” might be in the manufacturer field.
- “Charger” in the model field.
- “John” in the responsible worker field.
Tip: The words don’t need to be next to each other. As long as all are present somewhere, the asset will show up.
Exact Match Search Using Underscore
Use an underscore _ to search for an exact phrase. Example: Hilti_M900
The system treats it as one phrase: “Hilti M900”
- It only shows assets where the full phrase appears exactly in that order.
Tip: Use this when you want very specific results.
On which fields do search applied?
- Asset Name
- Scan Code
- Notes
- Serial Number
- Storage Location
- Inventory Number
- Hilti Asset Owner Name
- CCMS Number
- Model
- Description
- Cost Code
- External Asset ID
- Asset Group Name
- Manufacturer Name
- Template Name
- Cost Code
- Responsible Employee Name
- Responsible Employee Email
- Responsible Employee Designation
- Owner Name
- Last Updated By
- Current Location Manager
- Default Location Manager
- Fleet Cost Center
- Fleet Purchase Order Number
- Fleet Inventory Number
- Fleet Organization Reference Number
- Label Names
- Current Location Name
- Default Location Name
- Vendor
| Input Type | How It Works | Example |
| Spaces | Broad search; splits keywords and finds them anywhere in asset fields | "Hilti Charger John" → matches assets containing all three words anywhere |
| Underscore | Exact phrase search; keywords appear together in the same order | "Hilti_M900" → matches assets containing “Hilti M900” exactly |
This design allows you to quickly perform both flexible and precise searches, depending on their need.
