Before you can delete an employee, make sure you have the following:
- Delete Employee Permission: This lets you remove an employee from the system. User need “Delete Employee” permission.
- Edit Employee Permission: Often needed along with delete permission, this allows you to update employee details.
Admin Role: Only an admin can delete another admin. Make sure you have admin access if needed.
Check this before deleting: The employee should not be linked to any assets, locations, or other items. If they are, remove those links first.
