FAQs and Troubleshooting - Onboarding Hilti Consumables
FAQs
  • How many consumables can I add at once?
    • The limit is 100 items per onboarding session.
  • What happens if I enter a wrong item number?
    • You’ll see a message at the top showing which item numbers couldn’t be found.
  • Can I still add non‑Hilti items?
    •  Yes. Use the regular “Add Quantity Item” flow as before and fill in the fields manually.
  • Do I need to allocate to a location?
    • Yes. You must select a default inventory location to complete onboarding.
       Note: At this point you cannot allocate it to an employee or storage asset. That is possible only once the quantity item is onboarded.
  • Will updates from Hilti’s catalogue automatically refresh my items?
    • No. Once onboarded, items stay as they are until you manually edit them in ON!Track.
  • What number is the Scan code field pre-filled with?
    • The scan code field is pre-filled with the GTIN-13 (former EAN13) code which is compatible with the bar code on the packaging of the Hilti consumable.
  • Which Hilti Consumables can I add with this new feature?
    • Majority of the Hilti Consumables are compatible with this feature, However some special items (e.g. Kits) requires manual setup.
  • How long does it take for an item to appear in ON!Track if it’s not searchable immediately?
    • If your newly onboarded Quantity Item doesn’t appear right away, please wait a few seconds. The system may need a short moment to process and load the item into ON!Track.
Troubleshooting
IssuePossible CauseWhat You Can Do
Item not foundIncorrect or invalid item numberDouble-check the number and format (no spaces or letters)
“Item already exists” messageThe item was previously onboardedSearch your Quantity Items list to confirm
No items in “Recently Purchased”No Hilti purchases in the past 12 monthsTry using the “Search Catalogue” option
Missing fields preventing onboardingRequired fields not filledReview highlighted rows and add missing info
Default location errorSelected location was deletedRe-select a valid inventory location
0 out of 1 found this helpful
