The Switch Account feature lets you move between different ON!Track accounts without logging out and logging back in.
If your organization uses more than one account (for example, for different locations, teams, or projects), you can switch between them easily and continue your work without interruption.
This feature works the same on both web and mobile. You will only see it if you have access to multiple accounts.
Why is this useful?
Earlier, switching accounts was a slow process because you had to log out, log in again, and find your work each time. This made it difficult to move quickly between accounts, especially when you needed to switch often.
Now, you can switch accounts instantly without leaving your current screen. This makes it much easier to move between tasks and access information quickly, without losing time or breaking your flow.
