Customizing your view in ON!Track helps you focus on the information that matters most, reduce clutter, and find what you need faster.
You can customize how information is displayed without changing the actual data.
Instructions:
- Select Column Settings, the gear icon, or View Options.
- Choose the columns you want to display. Choose from various column options to customize the information displayed in your ON!Track view. Some of the key options are listed below:
Manufacturer and model
Name
Responsible Employee Name
Asset Category
Scan Code
Inventory Number
Description
Group Name
Label Names
Current Location Name
Default Location Name
Cost Code
Last seen
Last seen by
Idle time
Last Update
Last Service Date
Loan End Date
Fleet Cost Center
Fleet Currency Code
Fleet Delivery Date
Fleet Exchange Or Warranty Date
Fleet Inventory Number
Fleet Organization Reference Number
Fleet Purchase Order Number
- Hide columns you do not need.
- Save your changes if the option is available.
You can also arrange columns to make important information easier to find:
- Move frequently used columns to the left.
- Make columns wider for long names or descriptions.
- Make columns narrower for short values such as status or type.
Note:
- Common columns to keep visible include Name, Status, Manufacturer and Model, Responsible employees, Scan code, etc.
- Sorting and filtering help you focus on the most important records.
Examples of useful views
Here are some common ways customers set up their views:
Service planning: Show the last service date and next service date columns, then sort by next service date to see which assets are due soon.
Assets by type or location: Filter by asset type or location to see, for example, Akademie Hall 2.
Assets by label or status: Filter by a status or label to see a specific group, for example all assets marked as stolen.
Fleet exchange planning: For Hilti fleet assets, show the next fleet exchange date column and sort by it to plan upcoming exchanges.
Save Your Views
If ON!Track supports saved views, you can save your preferred settings and use them again later.
Examples include:
- Daily work
- Team overview
- Escalations
- Completed items
Use clear names so you can easily find the correct view later.
If you have administrator permissions, be careful when changing shared or default views because those changes may affect other users.
Customize the New Hilti Assets view
You can also customize the New Hilti Assets view. Open New Hilti Assets and select the columns and layout you want to display. This helps you focus on the information that matters most during onboarding and manage newly onboarded assets more efficiently.
Customizing your ON!Track view helps you organize information in a way that works best for you. Start by adjusting columns, filters, and sorting options, then save your preferred views for quick access in the future.
