How to create an asset with a template
ON!Track allows you to create and use asset templates, simplifying the management of your asset fleet. A template can be associated with multiple assets with similar attributes, including manufacturer, model, image, and description. Utilising templates helps you maintain consistency and efficiency throughout your assets.
Instructions:
  • Click the assets, then select "+" to add the asset.
  • You can start filling out the details to create an asset.
    • Enter the asset details
    • Enter the additional information.
  • Add services if the asset requires them (Optional selection)
  • Select the service from the dropdown, enter the status, and the next service date, and click "Assign."
    • Here you can view the service and its details.
    • Scroll down to drag and drop a file, or click to browse and upload any file and optional notes. Check the asset costs and click on "Complete".
  • The asset is successfully created.
  • You can view the asset in the Asset List.
If you want to add an asset template under the Administration Tab, you can check: How to add an asset template under the administration tab
If you want to add an asset template when creating an asset, you can check: How to add an asset template when creating an asset
0 out of 1 found this helpful
