What are asset service templates, and how do they differ from asset templates
Schedule and manage one-time or recurring services for tools, equipment, machinery, or vehicles through Asset Service Templates.
You can schedule services based on Period (i.e. days, weeks, months, years), Distance (note: heavy-equipment only), or Engine Hours (note: heavy-equipment only).
Further, you can specify if a service is critical. When you have an asset or equipment that has a Critical service overdue it can no longer be transferred. The user needs to be either an admin or have a role with special permission called "Critical service transfer" enabled in order to transfer the asset or equipment. This is to prevent the use of equipment that has a mandatory critical service like for example any laser measuring device and their calibration.
Each service name must be unique per account and is linked only to Assets or Asset Templates, not to Quantity Items.
A service can be attached to multiple Assets or Asset Templates but only once as an upcoming service per Asset until this service is completed. Multiple different services can be assigned to a single Asset.
What is the difference between Asset Templates and Asset Service Templates?
Aspects Asset Templates  Asset Service Templates
What it Does Stores common details of assets (like manufacturer and model). Schedules and manages services for assets (like maintenance).
How to Manage Created and edited through specific workflows or imports. Managed by authorized users in the Administration section.
Uniqueness Each template must be unique but can be used for many assets. Each service name must be unique.
How it’s Used Applied to assets when they are created. Attached to assets or asset templates to schedule services.
Assignment Can be linked to multiple assets.
  • Can be assigned to multiple assets
  • An asset can have only one upcoming service at a time.
Notifications Not used for notifications. Notifications are set in the Alert Settings.
Types
  • Global (created by Hilti)
  • Local (created by you)
Only one type: Service Template.
Creation
  • Created through specific workflows or imports.
  • System-generated templates are available. These can be copied and edited, but not deleted.
Can be created and customized by the user
When to Use When setting up or managing assets. To schedule and track services for your assets.
