Instructions:
- In ON!Track, go to the "Locations" tab, select an existing location and click on "Edit" to modify its details.
- Scroll down and ensure the "Settings for Hilti Automatic Refill" section is filled in correctly.
Blanket PO Number:
- If you can't open a Blanket PO number for Refill orders (the toggle is off), enter a new Purchase Order (PO) number in the PO number field before the Refill order runs.
To learn more about how to add a new location to Refill, please check: How to add a new location to refill or check enabled refill locations
To learn more about how to change the desired stock levels for Refill, please check: How to add a new Hilti item to refill and change the desired stock levels
