How to set up Procore Integration
Procore is an easy-to-use construction management tool that helps you deliver high-quality projects safely, on time, and within budget.
By connecting ON!Track with Procore, you save time by avoiding double data entry and get a clear view of all your equipment on the project.
Integration use cases
  • Procore users are automatically added as workers in ON!Track.
  • Procore projects show up as locations (jobsites) in ON!Track.
  • Asset movements in ON!Track are recorded in Procore’s daily project notes.
Pre-requisites to get started with Procore Integration
Connect with Procore Connector
  • Click “Connect” to start linking your Procore account.
  • Choose your company from the dropdown list (these come directly from Procore).
  • Click “Connect” again to confirm.
  • Once connected, the button will change to “Go to Available Integrations.”image (22).png
  • You’ll now see a list of Procore integrations. Click “Configure New” to start syncing your data.
The following are the data mapping details:
  • Location Mapping:
    • Your Procore projects automatically become jobsites in ON!Track.
    • If a Project Manager is assigned in Procore, they’ll be set as the Location Manager in ON!Track.
    • When a project is marked inactive in Procore, it will also show as inactive in ON!Track.
  • Employee Mapping:
    • Your Procore employee list is used to create employees in ON!Track.
    • Each employee is automatically set as a Location Manager in ON!Track.
    • Any new or updated users in Procore will sync with ON!Track every day to keep your records current.
  • Transfer Notes
    • When items are moved to or from a connected jobsite in ON!Track, the details are automatically added to the Daily Log Notes in Procore.
    • These notes include information about any tools, materials, or quantity items that were transferred so your team stays in the loop.
1 out of 2 found this helpful
