How to set up Fieldwire Integration
What is Fieldwire?
Fieldwire is a top-rated construction app used on over 1 million projects to keep field work running smoothly.  Now part of the Hilti family, Fieldwire combines its powerful tools with Hilti’s trusted name to help even more teams boost productivity.
How ON!Track + Fieldwire Helps You?
By connecting ON!Track with Fieldwire, and you save time by avoiding double data entry, making your field operations faster and more efficient.
Integration use cases
  • Employee details from Fieldwire are automatically added to ON!Track, not need to enter them twice.
  • Project and location info remains in sync between both systems, so everything stays current.
Pre-requisites to get started with Fieldwire Integration
  • User Onboarding Completed
  • Fetch the token ID from Fieldwire by steps below:
    • Log in to your Fieldwire account and navigate to the Account tab
    • Click on Manage tokens under APi settings section
    • Click on the new token and create a new token.
Connect with Fieldwire Connector
  • Click “Connect” to start the Fieldwire integration.
  • Paste your API token (from Fieldwire) and click Connect again.
  • Once connected, the button will change to “Go to Available Integrations.”
  • Click “Configure New” to begin syncing your data.
