Search and how to use it
Smart Search
Asset search is now smarter, faster, and easier to use (web and mobile)
Overview:
The search feature in ON!Track helps you quickly find your tools and equipment. You can search by typing keywords or entering a code.
The system shows the most relevant results first, which makes it easier to find what you need. Keeping your data consistent will also improve your search results.
Searching by Scancode or Serial Number:
Each asset has a unique scancode and often a serial number. You can scan the code or type the serial number in the search bar to find the exact item instantly.
This is the fastest way to search for a specific tool or equipment.– if you have the code or serial, enter it, and the exact asset will appear at the top of your results.
Intelligent Search for Names and Types (Fuzzy Search):
The search works even if you make small spelling mistakes or use different formats. For example, “Combihammer,” “Combi hammer,” or “Combi-hammer” will all show the correct results.
In practice, this means that even if an asset was entered as “Combi-Hammer” in the system, a search for “Combihammer” (without the hyphen) will still find the correct assets.
Minor spelling errors or plural/singular differences will not prevent you from finding your tools. This means you can still find your tools even if the spelling is not exact.
Results Sorted by Relevance:
The system shows the most accurate results at the top. Exact matches appear first, followed by similar results. If there are many results, check the first few items as they are usually the closest match to what you searched.
For instance, if you search “CombiHammer TE 6”, any asset whose name or description exactly contains “TE 6” will show up before those that have only a close variant of that term. By prioritizing the most likely matches first, the system saves you time
Note: If you get many results, check the top few entries first; they should be the closest match to what you searched.
In case special characters:
If your language uses special characters like ö, ä, or ü, the search still works properly. You can type simple letters like o, a, or u, and the system will still show the correct results.
This allows users to find the correct results even if they don’t type special characters in their search.
Ensuring Consistent Data for Better Search Results:
While the search feature is robust, the quality of your asset data plays an important role in search effectiveness. Inconsistent data entry (for example, some employees entering “Drill HD” while others enter “Heavy Duty Drill” for the same type of item) can lead to a situation where multiple near-matches appear. The search will still find them (thanks to fuzzy matching), but having standardized naming conventions will make your results even more accurate and easier to scan.
We recommendUsing clear and consistent names for your tools makes search results easier to understand. Avoid using different names for the same type of item. When data is consistent, it is easier to find the right asset quickly.
For example, ensure that all combihammers are recorded with a consistent naming format. This kind of data cleanup and uniform entry will reduce confusion and improve the relevance of search results. (Related articles: Using Asset Category and Type Standards, Bulk Editing Assets for Consistent Names – refer to these for guidance on cleaning up data.)
Conclusion:
The ON!Track search feature makes it easy to quickly find your tools and equipment. You can search using codes, serial numbers, or keywords, and the system will still work even if there are small spelling differences. By keeping your data clear and consistent, you can make your search results more accurate and easier to use.
0 out of 1 found this helpful
