How automated transfers work
Automated transfers occur when sensor-tag-enabled assets reach a new gateway-enabled location, provided the automated transfer feature is enabled and the tracking entity is different from the assigned location.
Enabling Automated Transfers
  • Settings: Automated transfers can be enabled in the company settings at the tenant level.
  • User Permissions: Only users with permissions to manage company settings can enable or disable automated transfers.
Requirements for Automated Transfers
  • Supported Assets:
    • Automated transfers are only supported for Sensor tag-enabled assets.
    • Quantity items, Nuron, and any IoT tools without an active Sensor tag are not supported for automated transfers.
  • Gateway Tracking:
    • Automated transfers work only if the asset is being tracked by a Gateway-enabled location or Storage asset.
  • Triggering Automated Transfers:
    • The automated transfer is triggered when the asset arrives at a new Gateway-enabled location/storage asset.
    • The asset’s assigned location/storage must be different from its current tracked location/storage.
  • Single Gateway Tracking:
    • The asset must be tracked by one Gateway-enabled location/storage asset only.
    • If the asset is tracked by multiple Gateway-enabled locations, automated transfers will not be triggered.
  • Origin Location:
    • The asset should not be tracked by the origin location's gateways to trigger an automated transfer.
  • Transit State:
    • If an asset is already in a transit state (moving between locations), automated transfers will not be created, even if it's tracked by a Gateway-enabled location/storage asset.
Transfer Completion
  • Alerts: Upon successful transfer, any previous unexpected asset removal alerts for the asset are closed.
  • Transfer History: Transfer History tracks recent asset moves, including where, when, and who handled them. Users can view the latest transfer details and the full history for each asset.
You may also be interested in Suggested Transfers! If so, please check: Suggested Transfers
You may also be interested in Automated Transfers! If so, please check: Automated Transfers
