How to transfer assets or quantity Items via smart inventory using mobile application
Roles: Administrator & Employee | Device: Mobile App
ON!Track has 2 different ways of performing transfers. Those are:
1) Quick Transfer: This feature allows you to transfer individual assets swiftly to job sites, warehouses, storage assets, or workers. You can use Quick Transfer to immediately assign one asset or a quantity item to a responsible employee, a location, or a storage asset.
2) Transfer: This feature allows you to transfer multiple assets, especially to different job sites, containers, or workers. Compared to "Quick Transfer", you can also set a return date and add notes.
Good to Know:
  • You must have permission before moving assets or changing item quantities.
  • Note: Smart Inventory scans one gateway-enabled location or storage asset at a time.
  • When you transfer an item, its “Assigned to” value is updated.
  • You can transfer items to a location, storage asset, or worker.
  • The transfer cart can hold up to 500 items.
Instructions:
 For Assets:
  • Open the ON!Track mobile app.
  • Go to the gateway-enabled location or storage asset.
  • Open Smart Inventory.
  • Review the category counts and open the relevant list.
  • Select the asset or assets you want to transfer.
  • Add them to the Transfer Cart or start the transfer flow.
  • Choose the destination location, storage asset, or worker.
  • Review and confirm the transfer.
For Quantity Items:
For quantity items, use the standard mobile transfer workflow where available. The logic is the same as on web platform: select the quantity item allocation, enter the quantity to move, choose a destination, adjust the item status if needed, and confirm.
  • Open the relevant quantity item or allocation.
  • Enter the quantity to transfer.
  • Select the destination.
  • Adjust the status if required.
  • Confirm the transfer.
