Roles: Administrator & Employee | Interface: Web & Mobile
The Utilization information and charts feature offers insights into engine usage over the past year. It provides three data points:
- Working Hours - When the engine is on.
- Idle Hours - When the engine is on but not working
- Engine Off - Total hours minus working and idle hours
View summary and detailed utilization for a selected period. Monitoring daily engine usage minimises downtime and improves equipment planning. This feature is especially useful for project managers, service technicians, drivers, and workers.
Two visualisations of this data are provided in ON!Track:
Utilization Summary Chart:
- Found in the Asset details panel on web and mobile platforms.
- Appears only if there is at least one utilization record.
- Shows engine utilization for the last 30 days by default.
- Users can select a custom date range up to 365 days.
Utilization Detailed Chart (only web application):
- Accessible via the "View details" link below the summary chart on the web (not available on mobile).
- Opens a page with a daily bar chart of engine utilization.
- Allows date range selection up to 365 days.
- Users can choose which data to display and hover over bars to see detailed values.
Functionality:
- Engine utilization data is received every hour from Hilti Iot.
- Engine hours are rounded: 0-30 minutes show as 0 hours, and 31-60 minutes show as 1 hour.
- Detailed utilization is available only on the web interface.
- Utilization summary can be viewed on both web and mobile platforms.
Advantages:
- Reduce machine downtime by tracking daily engine usage.
- Plan heavy equipment deployment more effectively by monitoring daily engine usage.
Note:
The "Idle" legend will only appear if there is idle data received. If no idle data is present, the "Idle" legend will not be shown at the bottom of the chart.
To see utilization chart, you need the following functionalities for heavy equipment.
| Service Functionalities for Heavy Equipment | WEB | MOBILE |
| View Summary chart | YES | YES |
| Change the duration on the Summary chart to view utilization for different dates | YES | YES |
| View detailed utilization | YES | NO |
| Adjust the duration on the Detailed chart to view different date ranges. | YES | NO |
| Heavy Equipment Utilization Report and Services Report Templates: | YES | NO |
If you are interested to learn how to view and adjust the duration of the utilization summary chart for heavy equipment, please check: How to view and adjust the duration of the utilization summary chart for heavy equipment
If you are interested to learn how to view detailed utilization and adjust the duration on the chart to see different date ranges, please check: How to view detailed utilization and adjust the duration on the chart to see different date ranges
