How to view detailed utilization and adjust the duration on the chart to see different date ranges
Access the "Detailed Utilization" page from the Summary panel to see daily utilization. Adjust the duration to view detailed utilization for different periods.
Instructions:
  • Go to the "Asset" and search for the required heavy equipment asset.
  • Scroll down to the Asset Details section and open Utilization.
  • Click "View Details" to see the asset's detailed utilization, including idle time, working hours, and engine-off hours.
  • Here, you can view the asset's utilization in a graphical format.
  • Choose a date range of 7, 15, or 30 days, or create a custom range (up to 1 year).
  • Select the tabs for idle time, working hours, or engine-off hours to see the corresponding graphical data.
  • Hover over a bar in the graph to view detailed data for that day, including idle time, working hours, and engine-off hours.
Note:
The "Idle" legend will only appear if there is idle data received. If no idle data is present, the "Idle" legend will not be shown at the bottom of the chart.
If you are interested to learn how to see utilization for heavy equipment, please check: How to see utilization for heavy equipment
If you are interested to learn how to view and adjust the duration of the utilization summary chart for heavy equipment, please check: How to view and adjust the duration of the utilization summary chart for heavy equipment
