What does historical utilization mean, and how far back can the data be viewed
Roles: Administrator & Employee | Interface: Web, Mobile
Historical utilization for heavy equipment shows records of how the equipment was used, including working hours, idle time, and engine-off periods.
This data helps you track usage over time and is available for up to 365 days from the current date. Here is an example implementing the same.
Note:
The "Idle" legend will only appear if there is idle data received. If no idle data is present, the "Idle" legend will not be shown at the bottom of the chart.
If you are interested to learn how to view and adjust the duration of the utilization summary chart for heavy equipment, please check: How to view and adjust the duration of the utilization summary chart for heavy equipment
If you are interested to learn how to view detailed utilization and adjust the duration on the chart to see different date ranges, please check: How to view detailed utilization and adjust the duration on the chart to see different date ranges
0 out of 1 found this helpful
