You can use the following methods to verify if the Stationary Gateway (AI G125) is displaying incorrect/no location, or if it is not transmitting any data:
- Ensure the gateway is plugged into the power source.
- Verify the correct location is set on ON!Track.
- Check the LED status on the gateway:
- Solid Green: The gate is successfully connected to the internet.
Solid Yellow:
- If it turns green in 30 minutes, the connection is successful.
- If it remains yellow after 30 minutes, please contact support.
Blinking Yellow:
- If it turns green within 20 minutes, the gateway is functioning properly
- If it stays yellow after 20 minutes, please contact support.
To learn more about the Vehicle or Telematics Gateways (TU-600) showing an incorrect location/no location/is not sending any data, please check: My vehicle is showing an incorrect location/no location/is not sending any data
