How does charging work for the Gateway?
Stationary Gateway (AI G125)
  • The charging is done via the power cable adaptor.
Note: The stationary gateway does not have an internal battery.
Vehicle and Telematics Gateways (TU-600)
  • The power is supplied by the vehicle or heavy equipment.
  • If the vehicle is turned off, the system draws power from its internal battery, which can last for about 2 weeks, depending on the battery level of the van or heavy equipment.
Note: The gateway never uses the battery to its limit and the gateway battery always keeps a small percentage as backup to assure device stability.
0 out of 1 found this helpful
