How to edit assigned service for the heavy equipment using mobile application
Roles: Administrator & Employee | Interface: Mobile
You will learn to edit the service details for heavy equipment using the mobile application.
Instruction:
  • Open the dashboard, click "Assets" and select the required asset.
  • To edit the service, go to the asset details and scroll down to the "Upcoming Services" section. You can view the assigned services for the required asset here.
  • Open the service details, click on the three dots, and select "Edit." Update the schedule for the next service as needed, then click "Save Changes."
  • The service will be updated in the asset details.
If you are interested in learning how to edit the assigned services for heavy equipment using the web platform, please check: How to edit assigned service for the heavy equipment using web platform
If you are interested in learning how to assign services for heavy equipment using the web platform, please check: How to assign services for heavy equipment using web platform
If you are interested in learning how to assign services for heavy equipment using the mobile application, please check: How to assign services for heavy equipment using mobile application
