Why is the Connected Locker beeping?
Symptoms:
  • You hear a loud beeping sound coming from the Connected Locker.
Possible causes:
  • One or more Locker doors might still be open after the allowed time.
  • The door sensors might not be working correctly.
  • There could be a software issue or temporary malfunction with the Locker’s software.
Resolution steps:
  • Check the Doors:
    • Make sure all Locker doors are fully closed and securely locked at both the top and bottom.
      • Check the Physical Key Locks:
        • Make sure the top lock is turned counterclockwise and the bottom lock is turned clockwise.
        • This ensures the door pins can lock in place correctly.
  • Inspect the Folding Door Pins:
    • Look at the pins on the folding door to make sure they’re not bent or damaged.
    • They should be standing straight up in a vertical position.
  • Restart the Locker:
    • While the doors are closed, unplug the power cable from the locker.
    • Wait a few seconds, then plug it back in to restart the system.
To get further support on this topic, please contact your Hilti representative.
To learn more about how to change the desired stock levels for Refill, please check: How to add a new Hilti item to refill and change the desired stock levels
To learn more about how to manage Locations / Cost Centres for the Connected Locker, please check: How to manage locations/cost centers for the connected locker
To learn more about connected locker shows incorrect quantities on the display, please check: Connected Locker shows incorrect quantities on the display
