Connected Locker shows incorrect quantities on the display
Symptoms:
  • The quantities removed or returned don’t match what’s shown on the Locker display.
Possible causes:
  • The scale inside the Locker may not be working properly.
  • The scale might need to be recalibrated.
  • The item is too light for the scale to detect accurately.
  • There could be a software issue with the Locker.
Resolution steps:
  • Try to remove/return an item inside the malfunctioning scale:
    • No Weight Detected?
      • If the scale doesn’t detect any weight at all, it may be broken and needs to be replaced.
      • Please contact your Hilti representative to start the support process.
    • Wrong Quantity Detected?
      • If the scale shows incorrect quantities, it likely needs recalibration.
      • Please contact your Hilti representative to arrange this.
  • Still Not Working?
    • If the issue continues, please reach out to your Hilti representative to initiate further support.
Important Note on Item Weight Detection:
  • Very light items may not be accurately detected by the Locker’s scale.
  • To ensure proper tracking, it’s recommended that each item weigh at least 10 grams.
To get further support on this topic, please contact your Hilti representative.
To learn more about connected locker beeping, please check: Connected Locker is beeping
To learn more about connected locker doors that do not open using the RFID key fob, please check: Connected Locker doors do not open using the RFID key fob
