August 2025 - Release Notes
Storage Asset Export
Now you can export storage asset details with ease.
  • Open any storage asset
  • Go to its child page
  • Click the Export button
You’ll get a single Excel file with both the parent asset and all its child assets, perfect for quick reporting and inventory checks.
Enhanced Data Privacy
Admins now have more control over employee data privacy.
  • You can mark the entire address block as private when adding or editing employee records.
  • Emergency Contact and Home Address are now private fields.
  • Users with “View” permission will still see non-private employee details.
This helps protect sensitive information while keeping your team data accessible where needed.
Smart Map: Last Seen Export
You can now export the last used date and time of your smart assets directly from the Smart Map export feature. With Smart Map export, you can download a file showing:
  • Where each smart asset was last seen
  • When it was last used
All in one easy-to-access file, great for tracking and planning.
Unite - Delta Support for Quantity Items:
Speed up your syncs and simplify your integrations. Use a time-based filter in the GET API to
  • Retrieve only the records updated within a specific time frame
  • Reduce data volume and speed up syncs
  • Simplify your integration logic
Just add a time-based filter to your API request to get started.
Unite - Stock Units APIs:
You can now create, update, and delete stock units using our new UNITE APIs. This gives you more flexibility and control in your integrations.
Unite - New Asset Tracking Attributes:
We’ve added two new fields to the GET Asset API:
  • registeredBy: See who registered the tool
  • registerDate: Know when it was registered
This helps improve tracking and auditing of your assets.
112 out of 147 found this helpful
