- Go to the quantity items list, choose the item you need, then click the side arrow next to "Manage Purchases" to view or update purchase details.
- Here you can add, edit and delete purchases. Please note: only one purchase can be deleted at a time.
Add a Purchase
- Click the plus sign to add a new purchase.
- Fill in the required fields, Purchase date, Purchase quantity, and Purchase unit.
- You can also add rest of the ownership details, attachments, and notes if needed.
- The unit is set by default but can be changed.
Edit a Purchase
- Click the edit (pencil) sign to edit a new purchase.
- You can edit add the ownership details, attachments, and notes if needed. and click on Done.
Delete a Purchase:
- Click the delete (bin) sign to delete a new purchase.
- The purchase will be deleted.
Note:
- Currency Selection: When entering a price, you must select a currency. The default is based on the company’s unit of measure, but it can be changed to match the currency used in the purchase.
- Handling Errors: Be aware that entering a price with three decimal places may cause an error and prevent the purchase from being saved.
- Language Settings: If using a different language, check that all fields and messages are properly translated to avoid confusion.
