Passive Tags overview
Overview
Passive tags are printed identification labels attached to assets. Each label has a scannable code (barcode, Data Matrix, or QR code). ON!Track uses this code to link the physical asset to its digital record in ON!Track.
Why use passive tags
  • Passive tags offer a simple and low‑cost way to identify assets using a phone.
  • They do not need batteries, signals, or extra hardware.
What Problem They Solve
Passive Tags help answer everyday questions like:
  • Which tool is this exactly?
  • Is this tool registered in our account?
  • Who is responsible for it and where should it be?
They create a clear link between the physical asset and its digital record in ON!Track.
How passive tags help your business
  • Lower admin effort: Less time spent searching records or fixing mistakes.
  • Smoother daily work: Faster identification means less disruption.
  • Clear responsibility and traceability: Each tool has a consistent identity across teams and sites.
  • Strong base for future improvements: Once assets are labeled, it’s easier to standardize processes or add advanced tracking later.
Benefits of using passive tags for your business
  • Quick and clear identification: Scanning instantly shows the correct asset record.
  • Fewer errors: Users don’t need to type IDs or search long lists.
  • No electronic maintenance: The labels have no battery and work as long as they remain readable.
  • Easy to adopt: Users simply follow: open app → scan label.
  • When a tool is repaired at a Hilti Tool Service Center and the label is replaced, the new scan code is automatically married to the too
Use cases for passive tags
  • On the jobsite: Workers scan a label to confirm the asset before reporting an issue, requesting a replacement, or logging usage.
  • In warehouses and tool rooms: Staff scan labels when issuing or receiving tools, or while checking shelves and racks.
  • During handovers: When tools move between people or locations, scanning ensures the right items are selected in ON!Track.
  • Non‑Hilti Tools and Mixed Fleets : Labels can be applied to non‑Hilti tools, allowing all assets to be managed in one system.
How it works
Think of a Passive Tag as an ID card for your asset:
  • A unique code is printed on a label and attached to the asset.
  • The code is linked to the asset record in ON!Track.
  • A user scans the label using the ON!Track app.
  • ON!Track opens the matching asset record so actions can be taken.
Hilti Tag & Scan Service
  • For Hilti tools, Hilti attaches the tag at the warehouse before shipment or at the Tool Service Center during repair.
  • The scan code is already linked to the tool before it arrives.
  • Different Label Types:  AI L2 (small label), AI L5 (large label), AI T35‑H (metal tag) and AI T43‑P (hanger tag)
  • Mobile Camera Scanning: Camera‑based scanning using the mobile app (no extra scanner needed).
  • Broad Barcode Support: Supports multiple code formats, including Data Matrix, QR, and common barcodes.
Installation
  • Choose the right label type based on the asset and environment.
  • Attach the label to a clean, dry, flat surface.
  • Place it where users can easily scan it.
  • Avoid areas that are scratched, covered, or hard to reach.
Limitations and Requirements
  • Manual scanning is required: Passive Tags do not broadcast signals. Someone must scan them with the app.
  • The label must remain readable: Scanning may fail if the label is damaged or dirty.
  • Consistent labeling is important: Best results come when all relevant assets are labeled correctly.
  • Scan code uniqueness:
    • Scan codes are unique within ON!Track accounts
    • Codes printed by users may not be globally unique
    • Can be up to 36 characters and support letters, numbers, and UTF-8 characters including non-Latin scripts.
    • Hilti‑provided tags are managed to be unique by Hilti
Passive tags are low‑cost labels placed on tools. You scan them with a phone to open the tool’s record in ON!Track. This makes it easy to identify tools, see who is responsible for them, and handle daily tasks like issuing, returning, or reporting problems. Because passive tags do not need batteries or special hardware, they are a simple and durable way to start tracking tools and preparing for more advanced tracking later.
