Roles: Administrator & Employee | Device: Web
Smart Inventory on the web lets you see, in one view, which tagged assets are currently at a specific warehouse, jobsite, van or container that uses a gateway.
ON!Track compares what should be there (assigned assets) with what the gateways actually see (Smart Tags) and shows you:
Found – assets seen by the gateway
Not found – assets that should be there but are not seen
Unexpected – assets seen there but not assigned to that place
This gives you a quick, live inventory check from your browser, without walking around to count tools.
The Smart inventory check feature is available on both web and mobile platforms.
Follow the steps below to perform the smart inventory check for:
Stationary Gateway (AI G125)-
Vehicle and Telematics Gateways (TU-600):
Follow the steps below to perform the smart inventory check for Vehicle and Telematics Gateways (TU-600):
Search the Vehicle or Telematics Gateways (TU-600) in ON!Track web platform.
NOTE: To know how to search or access the Vehicle and Telematics Gateways (TU-600) check this article: How to search vehicle gateways (TU-600) and telematics gateways (TU-600) in the asset list
Now follow the same steps from Step - 3 (select the desired Vehicle or Telematics Gateways (TU-600) from search results to open the Asset details menu), to perform the smart inventory check for Vehicle and Telematics Gateways (TU-600).
If you are interested in checking Local Inventory, please check: How to check Local Inventory
