How to Set Up Services for Heavy Equipment: A Comprehensive Guide
Roles: Administrator & Employee | Interface: Web, Mobile
You can assign services to heavy equipment using service templates. To set up services, you need the following functionalities for heavy equipment.
Service Functionalities for Heavy Equipment WEB MOBILE
Create and edit service templates: How to create and edit service templates for heavy equipment YES NO
Subscribe to service alert: How to subscribe to service alerts for heavy equipment YES NO
Update alert settings: How to update alert setting for various alert categories YES NO
Assign services (Web Platform): How to assign services for heavy equipment using web platform YES NO
Assign services (Mobile Application): How to assign services for heavy equipment using mobile application NO YES
Edit assigned services (Web Platform): How to edit assigned service for the heavy equipment using web platform YES NO
Edit assigned services (Mobile Application): How to edit assigned service for the heavy equipment using mobile application NO YES
View service alerts and alert details (Web Platform): How to view service alerts and alert details for the heavy equipment using web platform YES NO
View service Alerts (Mobile Application): How to view service alerts details for the heavy equipment using mobile application NO YES
Complete services (Web Platform): How to complete services for the heavy equipment using web platform YES NO
Complete services (Mobile Application): How to complete services for the heavy equipment using mobile application NO YES
Reschedule services(Web Platform): How to reschedule services from alerts for the heavy equipment using web platform YES NO
Reschedule services (Mobile Application): How to reschedule services from alerts for the heavy equipment using mobile application NO YES
Edit historic service instance (Web platform - Recurring service?):How to edit historic service instance for heavy equipment using web platform of a recurring service YES NO
Edit historic service instance (Web Platform- Latest completed historic service): How to edit the latest completed historic service for heavy equipment on the web platform YES NO
Edit historic service instance (Mobile Application): How to edit the latest completed historic service for heavy equipment on the mobile application NO YES
  • Distance-based services
  • Engine hours-based services
You can schedule and track heavy equipment services. ON!Track will send alerts based on data from the connected Telematics Gateway (TU 600).
Limitations:
  • Service Association: Alerts for distance-based or engine hours-based services will only show if a Telematics Gateway is connected.
  • Scheduling Changes: You can update the scheduling frequency of a service template at any time. However, if the new frequency results in negative scheduling dates, the service will be marked as overdue, and the frequency will be displayed as negative.
Note - These types of services are not exclusive to Heavy equipment. You can associate these with any other asset too, however, alert generation will happen ONLY for Heavy equipment fitted with a Telematics Gateway.
0 out of 1 found this helpful
